I am having issues getting the back of the hood to sit level with the cowl. The hood is sitting about a 1/2" higher than the fenders in the back. Are my hinges shot or is there something else that I'm missing?
Have you tryed to adjust the where the hindges bolt to the inner apron. If you losen the bolt closest to the cowl and push up on the hood it should lower the hood at the cowl. After you do this, you will have to move the hood ahead where the hood bolts to the hindges because the hood will be too close to cowl once you make the adjustment. Hope this helps
