RDJ
67 Barracuda, 408 stroker, Edelbrock Air Gap intake.
I just switched from a Holley to an Edelbrock carb. The Edelbrock has an electric choke and the fuel inlet is at the top of the carb, so the drop type air cleaner I had (14" diameter, 3" tall filter element) won't fit. It hits on the choke.
There is not much clearance between the carb and the hood, and a raised type standard 14" diameter with a 3" tall filter won't fit.
I was thinking of using one of these Edelbrock 1002 air filters. Although until I have it, I don't know if it will fit.
I would like to get opinions on this or advice on what others are using in the case of clearance issues when you can't use a drop type air cleaner housing. I don't really want to cut the hood if I can help it.
Here is a link to Summit with the specs on the air filter.
http://www.summitracing.com/parts/EDL-1002/?rtype=10
