when i close the hood the drivers hood hinge wants to bow out and rub the fender. is this a grease issue or so other problem. car has been sitting a couple of years. wd40 did not help what do you guys know about this??
Sounds like one of the rivet type pivot pins in bound up.
You'll probably have to remove the hinge and apply heat and lube to the pin to free it up.
Just my 2cents
