Hood pin pics needed
homecloned
Can't re Member
Tampa Bay, Florida
I want to install some on my 71 Swinger and was wondering if anyone has pics with the hood opened as well to see the proper installation? If any one can help with this it would be much appriciated or if there is a link here allready. I did a search but came up empty. Thanks
i used the lock type of hood pins i bought these off ebay there stainless and has a rubber seal under each piece i think they were 30 bucks nicest set ive ever had they mount right wear your hood stop bump pins are located
these are cleaner then the hood pins with cables the cables will tear your paint up and if you ever forget to put the hood pins back in at 65mph you will wish you never had hood pins
Thanks guys. Those are different blackjax. I think I am leaning toward the cables method but those do look sweet on you ride.
Yes 70dart I wasn't sure were the cable attached to. I now know what that little dimple is for on the upper inside fender next to the hood bumper. (hole location)
