Hood scoops Worth it?
Skeeter007
Skeeter007
Barrie Ontario Canada
I have the opportunity to buy these for $335.00 Canadian delivered. Original
MOPAR scoops off of a Super Bee. Going to put them on my Scamp? Over priced or just right for what they are? Complete with chrome and all studs.
335 shipped aint real bad. If you ever look at a set of repops, you will understand how much better the OEM ones are.....Its just money, and those will look a lot cooler than some green paper bolted to your hood!
I would not install a hood scoop(s) unless it or they were functional. Period. End of story. Over and out. Roger wilco.
I noticed a gentleman selling templates. Would this work for me? Also the underside of the hood seems to have the circles for the holes. Well most of them. Or is this scoop totally different than the regular Dart/Demon/Duster scoops.
Posted via Topify using iPhone/iPad
The scoops are the same, and not to step on anyone's toes here, you don't really need the templates.
The studs that mount the scoops from the under side of the hood go through the little holes in the bracing, if you understand what i'm saying.......
Here's a pic of the underside of a Dart hood.
in all my years , that is the first set I have ever seen that were non-functional from the factory, in other words , they are not cut out in front for air. the N96 option is a ram-air type induction and the scoops are functional , these are not.
Good for you! I have bought parts for my Dart that were too expensive, but I was willing to spend the money to get what I wanted. Enjoy them once they are installed.
I can see how they do not look functional from the one photo. The photo with the trim in front shows them open. Weird angle I guess.
wow, ok , I see where the trim piece goes on now, crazy angles make them look solid in the front.
