Hood Scoops
gunmetal72
Life is a dark ride
Sicamous B.C
I put a set of scoops on my Duster and I have noticed that the inner structure of the hood has pulled away from the sheet metal. No damage to the hood, I would just have to re-glue it to the inner structure. I am not sure if anyone has ran into this, but I was thinking i would cut holes under the scoopes to make them some what fuctional and I thought by cutting holes, it would take the pressure off the outer sheet metal as the air would flow would pass through to the engine compartment. I have seen the holes in a Dart hood but never on the Duster. I am hoping someone might be able to give me some info as to where the hole are cut or perhaps a diagram.
x2^ measurements are always good. check em out. lucky for me when i bought my demon the previous owner had it already done.
