BHB4408
BHB4408
Hi Racers: Putting a built OEM 440-Block Engine in my 1972 Swinger I bought new Hooker Super Comp Fenderwell Header. I put the Headers in before I installed the engine. But trying to match the headers up to the heads, they don't seem to fit. I removed the OEM brace underneath the car that flowed out to the Rocker Panels to make room for the collectors, but the driver's side won't quite position itself at the heads correctly, like the collectors need to move upward to line up the headers to the heads.
The passenger side is worse. The headers won't even come down the head due to the tight space between the heads and the shock towers. I've opened the cut-out in the fenderwells as wide as I can, but that side is still not fitting in the tight space.
I think I can get the driver's side to work, but Need some advice on how you've made your Hooker Fenderwells fit on the passenger side. Thanks in advance for your suggestions and guidance. Thank you,
