Horsepower Estimate
72ScampTramp
Scamp Tramp
Fort Dodge Iowa
Alright guys combo set...
.030 440
Lunati 60341 Solid cam (see cam card)
Real close to 9.7:1 compression ICON forged Pistons
Mildly Ported 452 heads Flow sheet attached
Dual carb Weiand Tunnel Ram 2x600 Holley carbs
Pro Parts 2" headers
Stock Stroke crank and rods
I'll go 535 if you can get the carbs to work together, you might want to consider an M1 with a 4 hole spacer and a 950. Think you'll gain back some of the bottom end you could loose with the tunnel ram and still pork out more horespower at top end. It's what I ended up with on a 440 I ran years ago that was a little more radical than yours. Just a thought.
Great cam choice!tight lash solids work great with high flow numbers.That cam will be a pussycat on the street,once timing and carbs are sorted out.Shift points gonna be 6000 to 6300,my guess.
