CrazyPete
the car is a 76 dart sport slant 6 its cranks slow even when cold after its running if you shut off the car and try to start again if it dont fire in the first few cranks it wont start feels like your draining the battery. The battery cables are pretty warm, the battery is smaller one but its only a few months old. Im not sure if its a starter problem or a battery cable issue. The battery holds at 12v so i know the battery is good, the charging system is really strong charging at 14v when running everything seems normal with the car. But everything is OEM on the car (30+ years old) not sure which thing to replace first. Thanks in advance
