How can I make my 750 Quick Fuel run leaner
jefflock
69 Dart 408 10.08 best pass so far
Kansas
As the title says: How do I make my 750 quickfuel dp run and idle leaner. It is way to rich right now. Thanks
You may have to set the primary blades correctly and adjust idle speed with the secondaries
simple answer is to drop the jets in carb to lean it out...and screw in idle mixture screws to lean out idle....especially if is a 4 corner idle carb..
best thing....how much cam is in engine and what kind of vacuum are you getting....and is the timing set correctly....and what number power valve is in the carb..
I've dropped the jets several sizes. 4 corner idle set a 3/4 turn. cam is comp 242/246 507/510 only 6 to 8" vacumn 2.5 pv timing is 18 int 36 total
