I was thinking about how a machine shop cc's cylinder heads? Would milling the heads work?
Do all the seat work, pick valves etc.. then measure and mill. Only sometimes do you end up milling 1st and that is because the seats are cut proud in the chamber 'not very deep' and so you would end up cutting into them some at say.. the 30 angle.I was thinking about how a machine shop cc's cylinder heads? Would milling the heads work?
How can the combustion chamber sizes be equalized, say 2 chambers are 64cc and the others are 62cc how would you get them all to 62cc's? Can this be done?@Dan the man The question's kind of vague. What are you asking exactly?
You gain in areas such as the parameter of the chamber 'tracing to the bore' or pushing the chamber edge out to the bore size...or you can skim the chamber around or on the plug side .How can the combustion chamber sizes be equalized, say 2 chambers are 64cc and the others are 62cc how would you get them all to 62cc's? Can this be done?
Well, I don't have one of those to my availability and it's not cost effective for me to have it done. I was really curious what was involved in the process.Flowbench
Yes, you open the chambers that are a little small, till they are all 64cc, then mill the head till they are all 62cc's, or whatever is desired.How can the combustion chamber sizes be equalized, say 2 chambers are 64cc and the others are 62cc how would you get them all to 62cc's? Can this be done?
Thanks for explaining that to me. I may ask the machine shop what the cost is for this. I'm most likely going to buy bare cylinder heads that way I can have the guides done, valve job and spring height doneYou gain in areas such as the parameter of the chamber 'tracing to the bore' or pushing the chamber edge out to the bore size...or you can skim the chamber around or on the plug side .
easy.
I'm pretty sure that a friend of mine has one of those, I know that he would let me borrow it. He's into all the "small " details of engine building. He likes to get what free / cheap horsepower he can. Back in the day he couldn't afford to buy a stall converter for his turbo 350 so he used a converter from a powerglide.Cubic Centimeters of liquid. So 50/50 of ATF and mineral spirts and a graduated beaker is how they are measured…
This is how I did it at home. It was inexpensive and easy! After measuring each chamber you can simply remove a little material on the combustion chambers that are too small (lower ccs) until they match the largest ones..
The flow bench measures just that. Flow. Not the chamber size.Flowbench
