How do you remove the rear quarter reflector lights on a 69 dart?
agepag
Richmond Hill Ontario
Went to see the my fathers car at the body shop and they can't figure out how to remove the reflextor lights? The body man says he can squeeze his hand in a small space in the trunk, but there's no way to remove the screw. Any help would be appreciated.
Thanks
there is screws under the lense on the rears...u must pop the lense out to remove the bezel...
Thanks! I will let the bodyman know
if the tabs break, all is not lost. You will have to use two sided tape. The tabs will at least keep the lens in place. And, Don't let anyone tell you B body sedans and hardtops lenses are the same. They aren't. The only car to use 69' dart rear reflectors is the 1969 Coronet station wagon.
