How many using an A500 overdrive ?
I have a 64 727 out of a truck, has the park brake drum on it
Is it shifted with an internal cable system ?.. I also had a 64 dodge A100 pickup that had a cable operated 727 ( thing is the cable operated external shift lever) the A100 did not have a parking brake on the trans.
I'm not sure but I think all A-500's were lock up. A-518 were either/or lockup/non lockup. If you don't want the LU function on a A-500 it can be disabled in the valve body.
When I was looking for info for the converter I bought from a member here for my a500
I have think it was "transtar" who showed an option for a TC that would work with the spline count of a lockup input shaft but that they "left the lockup clutch out of".
Yup. Internal cable. Only has the kickdown linkage sticking out the top.
