how much oil
2 fast z28
wisconsin
I'm taking my car to the track and wondering do you guys run a quart over I have a 340 with a stock pan running five quarts right now
No reason to add more oil, it will just slow you down a little. The 340 has a very good oiling system.
Really depends on your gauge readings? If it's a high volume pump and clearances are close to stock, you "may" be testing the waters...especially over time? That said, 65/70lbs @ peak rpm for just a quarter mile "should be safe imo.
This particular 340 car trapped @ 7000rpm's with 5.13 gears and ran on the street for years with no issues...
Keep the crank out of the oil. If the crank beats up the oil, and the air can't get out of it, the air-entrained oil is not the best lube, and will also make your lifters noisy, not to mention the loss of valve lift.
That's one reason for deep pans.
As mentioned too much oil will get whipped by the crank aerating it making it less effective and robbing horsepower. At the same time if your running a stock center sump pan with no oil control baffles and launch hard you may uncover the oil pickup on takeoff so watch the gauge real close on hard take off's because uncovering the pickup will starve the engine for oil which is really bad
