64ragtop
I've been hearing a "clunk" when shifting from reverse to forward gears in the ragtop. Been ASSuming that it was a U-joint getting flakey, like I've dealt with before. Put the car up on jackstands and turned the driveshaft expecting to see the slack in the U-joint, but didn't - it's in the rear housing. to make sure, I turned the yoke, not the driveshaft. It seems like there's about 1/4 inch of play. It's an 8.25, non Sure Grip. Is this something to worry about NOW, or plan a rebuild in the not too distant future, or use a thicker differential lube and don't worry? "yeah, SURE" on that last option - I've never had that kind of luck!
