Yote
4spdragtop’s article on rebuilding a Hurst shifter is very good. He mentioned that he did not remove the springs . I did, although mine is a Hurst, but not a competition plus. If you remove them be aware that one, (the smaller one IIRC) can be a real bear to reinstall !!
New words may be learned doing so, but it can be done.
Yote
Yote
