How to connect wiper reservoir
AussieDart
Victoria
Thanks Krazykuda & 57Dodged100 I now know what I need to do to get it set up.
Hello Everyone,
Happy Easter. I have a 68 Plymouth Valiant with a Slant 6. When I got the car the reservoir for the wipers was broken and the hoses missing. The reservoir is operated by a foot pump. Unfortunately all my manual tells me is how to install and remove the foot pump. It does not tell me the correct configuration for the hose from the foot pump and then to the wiper jets. What's more confusing is that the manual refers to 2 hoses being connected to the foot pump. Can anyone fill me in?
There is what they call an "F" connector with a loop on the back for a screw that screw onto the cowl. It has one larger hose coming in and two smaller ones coming out the same side.
Yes, there are two hoses coming off of the foot pump. I can't provide any pictures right now as it is dark out. I may be able to see if I can get any tomorrow...
Big hose from the foot pump to the reservoir.
Small hose from the foot pump to the F fitting.
one small hose from the F fitting to each of the spray tubes.
Bottom one goes to the passenger side and top to the driver side.
