How To Insert Quotes in a Private Message
MOPAR4Me
Orange County, CA
Can someone please provide guidance regarding my following question.
What are the steps to insert multiple quotes from prior dialogue in an ongoing Private Conversation, when sending subsequent replies within that same conversation?
_______________
Hold your finger on the first word you want to copy, then drag the second green arrow to the end of the quote > copy that.
Then go to your new posting and paste that in there.
Give that a try, it's one way.
You can screen shot the desired quote area, then past that in as a picture too. As I did above in the example.
Just go to conversation/pm.....look for reply/response you want to quote, then hit "quote" button. Repeat for all the ones you want to quote. Now go into reply box and click on "insert multi quotes".
Should work?
Should work?
Like this ^^^
You guys are good teachers. Those are options I don't use. I just use "Reply"
Did it on my laptop. And figured it out differently than the instructions above ! Probably never use it !
Thank you much, George Jets/4spdragtop, both methods work.
I will note that troubles arise for me when selecting/inserting many quotes at one time. I determined that the root of the issue is that the "Quote messages button shown in the first screen capture below, disappears/gets blocked behind the bottom page advertising banner. This is always located at the bottom of the website for me, resulting in me not being able to see/select "Quote messages button. I determined I can resolve this by taking the additional step (each time, since it defaults back), of selecting the advertising banner tab arrow shown in the second screen capture below. After this I am allowed to see/select the "Quote messages button. Thank you guys for all the help!
