I have a dodge 8.75 - 741 banjo rear end, the right hand side wheel bearing is toast. Check the end play and there is a alot of end play. So I removed the wheels and the 5 nuts holding the retainers on and the axles will not slide out, they will push in and out about an 1/8th of an inch.
How do I remove the axles so I can replace the bearings? Thanks
