How to remove spring from hood hinge ?
DonnieLawson
68 Barracuda
Middletown Ohio
Ok guys , I'm showing how little I know here .........
How do you remove the spring from the hood hinges ?
I got a fiberglass AAR hemi scooped hood awhile back , work is progressing faster on the Cuda now .
I hope to have it painted this summer :)
I have the hood hinges on the bench to change the springs with some lightweight hood springs I got from a member on here .
It looks like there is two small retainers at the center of the spring I have to remove to release the spring from the hinge.
I have the spring pressure released , its only connected to the hinge at the center of the spring .
Any tricks or tips guys ?
I very carefully pried mine off with a flat head screw driver. I then straightend with a ball peen hammer where needed. I used an old socket to reinstall.
