twister360
I have a 74 Duster and the seam sealer seperated over time and water became trapped behind this sealer and caused a small rust thru. It is on the DS rear quarter and is very small. There are other areas where the sealer has lifted and rust scale has formed. The condition of the metal in the trunk is solid, just some scale and bad sealer. My plan is to remove all the sealer and clean the trunk area to bare metal.
My question: Steps to treat bare metal, seal and repaint. What products do you recommend? I read a post where a member spray bombed his door jambs and coated with a clear top coat and it looked real nice. Would like to do something similar as I will not be able to get a painter to spary the trunk with a single stage or BC/CC.
Thanks for your help.
