Take a one sided razor blade, then put a single thickness wrapped around the blade on each end, leaving the blade exposed between them and then use it to "shave" the run down to reduce how much sanding that will be needed to level it out. The tape acts as a buffer/stand-off/shim to keep the razor from cutting your "good" paint and just the high spot...
I learned that trick from a paint shop guy...
