player1up
So I finally got fed up with my steering and decided that I'd go break something...drove the snot out of the Duster and the steering wander got worse. Figured it would be bad enough to see something loose or something. I was right, the steering box was loose.
So I removed all of the bolts, opened up the lock washers ( for more bite ), used some lock tight on the threads, and torqued the bolts to about 150ft/lbs and then some.....
BUT, the box pulls on the k-frame, I can watch it pull the driver side motor mount with the box.... The k-frame doesn't move at the frame attaching points, but the thing flexes... anyone have any ideas on how to stiffen the k-frame where the steering box mounts???
