Hows it look?
mycuda
Chicago/ Metro
Im an automatic guy.First and last early a 4-speed trans checking gears.
Took cover off just to check please let me know your expertise thank you.
Shifter seem to work fine I'm just worried about the trunnion rear tail bearing seems to have a little play is that normal.?
Is it something that I can do by removing the tail shaft?.also cover gasket #?
Thanks, Dave
