Do you plan on using standard bore pistons? Stock con rods?
This is a factory mess up block that came .020 over out of the plant. Will most likely go w a set of bushed free floating 340 rods seeing as it needs to be balanced anyways.Do you plan on using standard bore pistons? Stock con rods?
