1980volare
I've got a used set of hughes iron ram heads. 2.02 intake valve. Fresh valve job and just resurfaced. Heads have retainer to guide clearance opened up to accept .630 lift cams. Includes pushrods for use on la block. Also includes studs and guide plates to use sbc rockers. Has springs spec'd for a solid flat tappet cam. One head has a small crack as seen below. Pressure checks just fine and has been there all last year with no ill effects. Changing setups and have no use for these anymore and need them.
750 shipped from 45420.
