[WANTED] Hurst linkage rod, trans lever
NoCar340
The Original Partstitute
Legendary Member
Upper Peninsula MI
I'm looking for a Hurst reverse linkage rod stamped either "0078" or "213 0078". I could actually use two. It's not a factory part, it's for a Street Super Shifter. This photo has it backward from how it's installed on the transmission:
I'm also looking for a transmission lever, part number 105-0049, stamped "0049" or "0049 01". The lever has an enormous offset, around 1.5" as seen here:
These are parts of Hurst installation (linkage) kit #373 8613, which if anyone has a complete set I'd be interested in purchasing. Check your spare transmissions--these are aftermarket A/F-body overdrive parts. If you've got a shifter assembly with these two parts, I'd be interested in the entire shifter setup.
