1. joes68340s
    joes68340s Well-Known Member
    764
    38
    Dec 22, 2005
    Rescue CA.
    Local Time:
    8:49 PM
    Im looking for people who have Drag raced with the Ramrod shifter. I have only made one pass then had to leave as I couldnt get the shifter into 1st. I have since adjusted the T handle and it works for now. My main question is is it normal for the shifter to pop back into neutral when lifting off the throttle. My trans is slick shifted by Liberty.
  2. yellow rose
    yellow rose Overnight Sensation FABO Gold Member
    28,620
    25037
    Jun 19, 2015
    Central Washington
    Local Time:
    8:49 PM
    Yes. If your gear box is slick shifted without the syncros in it, you have to hold it in gear when on deceleration. It will pop out of gear. Is it slick shifted or pro shifted? If it has rings welded to the gear, that’s pro shifted.
    If it’s just slick shifted, you can grind every other tooth off the syncros, put the struts and strut springs back in with the syncros and it will stay in gear and still shift.
    Edit: I’ve driven RamRod and Vertigate’s on the street and at the track. I prefer the RamRod because it’s a smaller shifter.
  3. joes68340s
    764
    38
    Dec 22, 2005
    Rescue CA.
    Local Time:
    8:49 PM
    I previously had a Super Shifter 3 in it and it didnt pop out on deceleration but the Ramrod dosent take much to bump it into neutral. I have not looked at the trans. Im planning to go auto on the car. Just want to make some more passes before I change it over.
  4. Brad4406
    Brad4406 FABO Gold Member FABO Gold Member
    2,070
    325
    Apr 20, 2008
    Fairborn, OH
    Local Time:
    11:49 PM
    As yellow rose stated, it's not the shifter causing the transmission to pop into neutral. I ran a RamRod on the street and the track for many years and never had any issues, except for when I didn't have it adjusted properly. IMHO, it's the best shifter Hurst ever made.
    • Agree Agree x 1
    • joes68340s
      764
      38
      Dec 22, 2005
      Rescue CA.
      Local Time:
      8:49 PM
      Thanks
    • 1969383S
      1969383S FABO Gold Member FABO Gold Member
      6,310
      3219
      Jan 8, 2012
      Cumming, GA.
      Local Time:
      11:49 PM
      I ran that setup with a slick shift 833!
      Never touched the clutch after launch. Oh I miss those days!
    • 19DART66
      19DART66 Well-Known Member
      301
      133
      Nov 19, 2008
      Ballston Lake NY
      Local Time:
      10:49 PM
      I ran my RamRod shifter on a slick shifted 833 and now on a Jerico DR4 at the track and on the street and neither one ever popped out of gear when I let off the throttle. But I will say that both transmissions come out of gear with very little effort.
    • NITROTRIP
      NITROTRIP Active Member
      36
      2
      Oct 6, 2010
      DIXON NEW MEXICO
      Local Time:
      9:49 PM
      I ran verticle gates and super shifter 3's for years. Sounds like your throw stops are adjusted to
      tight. That will make a stock tranny drop out of gear. 1 shifter does the other don't.
      Rick
