Hydraulic brake light switch location
max512wedge
Bakersfield,California
On my 72 duster I’ve switched from power brakes to manual brakes due to putting in my 440 motor. I’m putting in a hurst line lock. Question; Is the Hydraulic brake light switch located under the dash on the brake pedal or under the car? Or was it on my power brake setup that I can’t find since I removed it over a year ago and I didn’t pay attention if the switch was on it? And if it was on the power brake setup that I no longer have or it’s not under the car or on the brake pedal. Which hydraulic brake light switch do you recommend to put on the hurst line lock to save me time from ordering and having to return the wrong part a couple times before I get the right one. I’m out of town on vacation right now and the grand babies are asleep and was just wondering where it may be located at. Thanks guys!!!
Mopars of that vintage use a mechanical switch located under the dash... There is no hydraulic switch...
There is or was a switch for the brake warning lamp at the proportion valve.
Switch for brake lights is mounted to right side of column support above brake pedal arm. Little screw is loosened to adjust switch position. Difficult to get at.
Hydraulic warning light is on the proportioning valve/distribution block- inner fender below the master cylinder.
Brake light switch is under the dash next to the upper pedal arm.
