mguner
How many is too many?
I've been using Jeep components on my Dart Sport's hydraulic clutch system with no issues. At the time I did the conversion I didn't have my new shop or lift so I "settled" for an OK system. The geometry is not what I wanted but works. I recently found that a slave cylinder from a Toyota Land Cruiser (3/4" bore) will get me the correct alignment on the stock clutch fork. I will either have to shorten the Toyota rod or use my existing piece. As the images show, the system I use now needs the slave to go down and closer to the bell housing which the Toyota unit should allow easily. I will have to mod my existing bracket a bit. I have seen others use a Nissan slave which is a bit shorter but it also required modifying the clutch fork which I did not want to do. The reinforcement plate / mount for the master cylinder also covers the hole for the old rod from the mechanical system.
