[Found!] Hydraulic Roller Cam for a 360 LA
Dodge72
Odd one out
Olympia, WA
I have a '92 360 LA engine in need of a hydraulic roller cam. Can be stock, just needs to be in good usable shape. Needs to be usable with stock converter and internals. If it comes with lifters, cool, but am not in need of them unless the cam is not stock. Let me know what you got, thank you!
EDIT : Found one!
Try calling a local machine shop. They might have one in stock or even a cam Regrinder which I got one for my 1991 360 and they didn’t need a core.
Why not buy a nice grind for better performance????
Update: the original roller cam from the engine was found and I'm going to do a quick drive to Delta Cams for a mild regrind. The reason I needed one is because it did not have a cam. Thanks guys!
