Hydroboost w/o power steering..possible?
Brakes for your Classic Mopar
  1. 71Demon
    71Demon Well-Known Member
    560
    33
    Dec 23, 2005
    Local Time:
    8:42 AM
    Has anyone successfully installed hydroboost brakes without having power steering? How do you plumb it? Tallon Hydraulics says the pressure out line from the hydro must go to a ps gearbox or it will not work. Thanks
  2. halifaxhops
    halifaxhops It's going to get stupid around here! FABO Gold Member
    65,299
    34648
    Jan 20, 2014
    Hoppyworld
    Local Time:
    9:42 AM
    Aftermarket pump?
  3. 71Demon
    560
    33
    Dec 23, 2005
    Local Time:
    8:42 AM
    Using stock pump
  4. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    18,853
    6204
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    8:42 AM
    I'm pretty sure ur s o l. Kim
  5. Bodyperson
    Bodyperson Pedal to the metal FABO Gold Member
    6,072
    8518
    Nov 26, 2015
    NW MONTANA
    Local Time:
    7:42 AM
    why do you want to?
  6. oldkimmer
    18,853
    6204
    Nov 11, 2006
    Local Time:
    8:42 AM
    Unless u can find some kind of an electric over hydraulic pump
  7. SLOPAR72
    SLOPAR72 Well-Known Member
    2,622
    2096
    Jan 5, 2016
    Richmond, VA.
    Local Time:
    9:42 AM
    I would ask why it won't work. It either has to be pressure or volume. Either of which I would think could be overcome but would take someone above my Paygrade to figure what needs to be done with a stock type Pump and make it work. The other option is go digging in Hot Rodder forums....
    JW
  8. 67Charger
    67Charger Member
    21
    10
    Feb 7, 2017
    Quartz Hill, CA
    Local Time:
    6:42 AM
    Pressure is a result of flow meeting restriction. Without having the definitive answer, I would conjecture the "restriction" is the valve in the PS box, and the hydroboost is flowthrough, in-line with the resultant pressure generated by the upstream pump meeting the downstream PS valves. The valve bypass freeflows back to the pump in the low pressure line. Think of it this way, if there were no PS box and the pressure line dumped back into the reservoir, the line presswure would be essentially zero, but flow would be at its max. The Hydroboost does not generate a restriction on its own, it just flows whatever pressure is present in the line through, and if it needs some, it diverts it, uses it, and has its own low pressure return.
    This being said, a hydraulic pressure regulator downstream of the hydroboost unit would build the necessary pressure and bypass the excess flow at low pressure.
