[WANTED] Hyper-Pak Slant 6 Exhaust Manifolds
I know it's a long shot, but any leads to a set of original Slant 6 Hyper-Pak Exhaust Manifolds (headers) will be much appreciated. Thank you.
Just a heads up. Those manifolds will not work with the 62-up starter.
The back casting will only work with the direct drive starter. You'll also need to change the ring gear on the flywheel or converter to match that
There is a a guy over at slant6.org that has a set and will eventually get them reproduced. Due to other issues it will be a long term project. They are out there so good luck with the search.
Thanks for the info -
Have a p/n by chance?
Yes, thank you.......casting #'s are:
2129899 front
2129900 rear
Did you get that intake from ebay that was in Hawaii? Good deal if so I think. Get any back story on the intake?
Hay Guys, can we start some privet messages (conversations) here please ... Thank you, we must do our best to keep the chit chat down in these adds :thumbsup:
