tyler_s18
k-member
ok so when i went from 318 with ac to my new rebuilt 360 w/o ac i am still working on the belt and pully set up. i believe the power steering is all set up correct just bolted to the head. it appears to line up with the crank pulley to. now the wierd part
i got the brackets from a mopar guy. one is a 3 hole triangle bracket that bolts to the water pump and thru the alternator to the head. i had to space that bracket between the water pump and the bracket. it also has the alignment bracket that seems correct. it only bolts one one spot on the water pump.
so all that might be right. it seems good enough. now i can not find a pulley to work with this set up. i think one that is 6" wide and 3" deep with 2 belt spots on it would work. what are all your set ups? i have asked this before and thought i had it right lol. i feel retarted lol. i can do a conversion to 4 speed and a motor swap and cant figure out simple pulleys lol if any one can help please do lol
