[FOR SALE] I have too many distributors sale!! 318 360 383 Electronic
66340SEDAN
FABO Member #3649
Minnesota
Ok, I found I have too many distributors so these are for sale. Lots of pictures.....Couple came from running engines in the last few years and others are untested and one looks like a reman one. They are all being sold as a core. All are small block except for 1 is a 383 one. Electronic ones, 1 points, 1 lean burn, the 383 is points. Also have 2 plug wire sets, both Accel heavy duty wires that look real good, just need to be cleaned up. If you want the wires with a distributor I’ll knock $5 off and will ship them together, other wise wires will be about $8 to ship.
Prices behind each listing , add $14 to ship a distributor in a medium USPS flare rate box. Want to buy more then one? Make an offer on the whole lot? Shoot me a PM! Must have paypal also.
here are the numbers:
#4111487-1978 318/360 4BBL, might be for a little red express? $40
#3874909-1975-1977 SB? $30
#365763-1973-1974 318 $30
Reman? Looks newer, no number or tag, single points...SB? $30
#4111784-1980 318 lean burn...looks crusty $10
#2875162-1968 383 single points $40
Mallory Unilite, can’t read part number, comes with resistor, Mallory coil, bracket, coil cover. It looks real clean inside and think this was on my uncles 318 a few years ago. $100
Accel wire sets, both 8mm, one set has high temp heat/boot covers. $20 each set.
How much for the Mallory coil in the box? With shipping to 47546, Jasper Indiana? Thanks
