I need a factory vacuum gauge repaired.
SKR8PN
Mansfield Ohio
Bought one while at the Nats this year and sent it in for "restoration". Apparently my idea of a restoration was mistaken. I thought that meant it would function as well as look pretty. Any thoughts on who can make one actually function as well as look nice?
The face is a mess, but will be covered by the center medallion on the lens. Mine seemed totally blocked when I got it and when I tried to apply vacuum to it and would not read at all. I used a TINY drill bit, I think they call them pin drills, and drilled a hole through the blockage in the inlet tube. Worked fine for years after that.
I have pin drills,so I will give that a shot!
