Well since most went to a single carb by 1970 it can be hard to find.
How I tuned mine was to set the carbs up to 500 cfm Edlebrock dual carb specs. The primaries were close to the single carb spec but the secondaries were quite a bit leaner, like .015 smaller jets in back.
Both carbs I have adjusted the same. Both are open about the same amount for idle and I found 1 to 1 linkage work the best for it. Progressive was too mussy at first and then came on too strong, with 1 to 1 the power comes on more evenly. Now before I got a 10 inch 3,000 stall converter having the linkage 1 to 1 shifted too hard - like barking the tires part throttle around town, not cool when it happed too often
Don't be intimidated, its not very hard, just time commissioning to have to remove 2 tops off the carbs and changing 4 secondary jets vs 2. Better to be too rich then too lean.
First thing is set the timing so its all in by 3,500, around 32 degrees and once jetted pretty close then you can try 34 - 35 degrees depending on fuel octane
