I need help with rear lower shock bracket
For the bottom bracket you have to take the U bolts off that hold the axles to the springs.
What are ya working on?
my 73 plymouth duster I was putting air ride on and the bolt broke off part of the screw and there is not enough room to fit everything back on
You can buy a bolt to replace it. You'll have to cut the stud off the shock plate and then drill it out to fit the new stud bolt. I also welded the nut and stud to the shock plate after I put it in. Worked pretty good.
Here is an example. I'd look around, if I recall mine were only 15$ from somewhere.
http://www.jegs.com/i/QA1/122/7888-108/10002/-1?parentProductId=756050
Posted via Topify using iPhone/iPad
