I think my gas tank is leaking
Fuel and Air Systems
  1. phaelax
    phaelax Well-Known Member
    352
    101
    Sep 3, 2014
    Ohio
    Local Time:
    1:25 PM
    Crawled underneath the car yesterday for a random inspection just because, and saw what appears to be fuel leaking from the tank. Might be hard to see in the pic, but it looks like it was leaking from where the tube connects into the tank then trickled down making the rest of it wet.
    As far as gas tanks go, looks pretty straight forward to remove but thought I'd ask here for advice first.
    http://imgur.com/ETrsXo8
  2. Bad Sport
    Bad Sport HALF A BUBBLE OFF Staff Member FABO Gold Member
    39,603
    22291
    Jun 12, 2010
    The Wolverine
    Local Time:
    1:25 PM
    Probably the seal where the filler tube goes in. I would get one and drop the tank, pretty straight forward procedure.
    It's possible there is a hole in the top allowing it to slosh out, but you won't know until you drop it.
    Just remember sparks + fumes = boom.
    Use caution while doing it.
  3. Mike440
    Mike440 Banned
    360
    5
    Dec 7, 2014
    Virginia
    Local Time:
    12:25 PM
    Might just be loose on the filler neck or may be the seal or could even be the filler neck it's self. By the looks of it I don't really think it's the tank it's self Altho I could be.
  4. TrailBeast
    TrailBeast AKA Mopars4us on Youtube
    21,682
    9490
    Mar 11, 2011
    Arizona
    Local Time:
    10:25 AM
    Looks like a rotten tube to tank seal to me, and it's a lot easier to get to from the top inside the trunk.
    Just pull the boot and it'll get real obvious.
    The seal is easy to replace (just pull the fill tube out and pop a new seal in and put the tube back in.)
    A little vaseline or grease helps to get the neck back in.
    Orrrrr if you just need something to do go ahead and pull the whole tank without checking the seal.
  5. Daves69
    Daves69 Well-Known Member
    5,653
    4008
    Feb 20, 2011
    WestOfChi
    Local Time:
    12:25 PM
    ^^^^^This.
    Then if it still leaks you know what you need to do.
  6. Chameleon
    Chameleon Dart Conissuer
    467
    21
    Apr 27, 2009
    Jacksonville, Florida
    Local Time:
    1:25 PM
  7. phaelax
    352
    101
    Sep 3, 2014
    Ohio
    Local Time:
    1:25 PM
    Thanks guys. I'm fortunate enough to have a jegs across the street for parts.
  8. pacuda59
    pacuda59 pacuda59
    5,702
    448
    Sep 20, 2005
    Pennsylvania
    Local Time:
    1:25 PM
    When I bought my car the owner boasted that it had a new gas tank installed. He didn't mention that they omitted the $10 rubber grommet. The old one was reinstalled and wrapped in duct tape and leaked like a sieve when the tank was filled.
  9. phaelax
    352
    101
    Sep 3, 2014
    Ohio
    Local Time:
    1:25 PM
    I wish it was only $10, cost me $25!
    New grommet installed. Removing the old, cracked and split one was easy.... Installing the filler tube through the new one was a PITA! I just used a little motor oil to lube it up but was still harder than heck getting that back in there.
  10. pacuda59
    pacuda59 pacuda59
    5,702
    448
    Sep 20, 2005
    Pennsylvania
    Local Time:
    1:25 PM
    Did you drop the tank?
  11. phaelax
    352
    101
    Sep 3, 2014
    Ohio
    Local Time:
    1:25 PM
    No, just pulled out the filler tube and shoved in the new grommet.
  12. FredS
    FredS Well-Known Member
    876
    66
    Feb 13, 2013
    Arizona
    Local Time:
    10:25 AM
    $25, yikes. MrMoparts has it for $14.
