I want this!!!
Plus,that one has been repaired. Look at the linkage tab on the #6 runner,big ol booger weld.:wack:
WOW!!! what a rip off!!!!
the ebay guy wants $375 for it used and you can get them new for $270????????
W.T.F.?!?!?! nice catch Red66GT
still it is cool! wounder why I never seen one before?
there you go 64Dart270 it's only $270 for your 64 dart!
looks like a great eye Candy, Light for performance and its a great conversation piece. I wonder what type of carburetors would fit? Any one barrel?
Yep,look for a matched set of carter bbs,or holley 1920's,or you can have the mounting pads drilled out and use BBD's,Holley 2280's,or even dual webers.
Offy has been making this manifold since the 60's.
OK so this is wicked cool and i got me thinking. Is it hard to make manifolds? If it can happen......a manifold with 3 one barrel carbs? 3-pak? kind like a six pack but with one barrels and a slant 6? it wouldnt flood it but i think thatd be the balls
$270 new confirmed. Much easier to swallow. As far as carbs go, you can do something as simple as two stock one barrels.
hang in there and wait a while.
I scored one on ebay with the linkage(you need it) for $40.00. and yeah it needed to be welded underneath in the heat tube transfer area (25 buck fix)
but it didn't bother the carb flow area, I have it setup for 2 1920's right now and am looking for a couple of re-buildable 2 bbls. It'll look awesome on the engine with a custom oval air cleaner
