I want to smooth out my ride...
Suspension, Steering and Chassis
  1. MrJLR
    MrJLR Built, not bought FABO Gold Member
    5,203
    5312
    May 14, 2015
    Chino, California
    Local Time:
    9:33 AM
    1968 Barracuda
    Rebuilt suspension 2 or 3 years ago with all new Moog components.
    New stock leaf springs
    Bilsteins on all 4 corners
    I just want it more cushy.....not quite like a Cadillac - but close!
    I don't autocross or drive nuts.....
    I DO like long awesome drives up the coast, around town, etc...
    Just seems like every bump wants to shake my teeth out!
    Any suggestions?
    Jeff
  2. JoeSBP
    JoeSBP RLTW!
    1,230
    663
    Jun 16, 2015
    NC
    Local Time:
    12:33 PM
    drop 5psi in each tire. that alone makes a big difference. I had an F250 that felt like it was on wooden wheels until I dropped the pressure from the suggested 50psi to 45'ish
    • Thanks! Thanks! x 1
    • MrJLR
      5,203
      5312
      May 14, 2015
      Chino, California
      Local Time:
      9:33 AM
      Hmmm....not a bad idea.
      I actually usually run them a couple pound hard....
      Jeff
    • JoeSBP
      JoeSBP RLTW!
      1,230
      663
      Jun 16, 2015
      NC
      Local Time:
      12:33 PM
      It will be noticeable for sure
      • JoeSBP
        JoeSBP RLTW!
        1,230
        663
        Jun 16, 2015
        NC
        Local Time:
        12:33 PM
        heck in my FV I can feel a difference in just 1-2psi, but then again the car only weighs 850lbs :)
        • Like Like x 1
        • d1970
          d1970 TODAY IS A GOOD DAY TO HAVE A GOOD DAY
          368
          164
          Sep 29, 2015
          Ontario, Canada
          Local Time:
          11:33 AM
          do you have sway bars on your car? They will help reduce the feel of bumps some and help going around corners to for a nice level smooth ride of the body
          • MrJLR
            5,203
            5312
            May 14, 2015
            Chino, California
            Local Time:
            9:33 AM
            I have a front sway bar but not on the rear.....
            Jeff
          • JoeSBP
            JoeSBP RLTW!
            1,230
            663
            Jun 16, 2015
            NC
            Local Time:
            12:33 PM
            It's those new fancy pants steel radial tires all y'all are running these days.
            Get yourself a nice quality set of bias-ply and it's smooth sailing brother!
            • Like Like x 1
            • Agree Agree x 1
            • MrJLR
              5,203
              5312
              May 14, 2015
              Chino, California
              Local Time:
              9:33 AM
              Lol......!
            • d1970
              368
              164
              Sep 29, 2015
              Ontario, Canada
              Local Time:
              11:33 AM
              nothing against Bilsteins shocks, but I find them to be a very firm shock to use. I believe the pressure in them is around 360 psi, to help stop the aeration of the fluid in the shock witch helps with dampening and fade. I've had friends remove them and replace them with KYB shocks and found the ride to be better. Just my 2 cents worth!
              • Agree Agree x 1
              • Disagree Disagree x 1
              • MOPAROFFICIAL
                MOPAROFFICIAL FABO Gold Member FABO Gold Member
                5,650
                4632
                Jun 1, 2016
                Beach
                Local Time:
                9:33 AM
                7o series tires, slant t bars, rubber bushings, napa shocks.
                It'll be soft and sway like...just wont corner very well.
                • MrJLR
                  5,203
                  5312
                  May 14, 2015
                  Chino, California
                  Local Time:
                  9:33 AM
                  Ya....I was wondering if the Bilsteins could be part of the problem. .....
                  Jeff
                • RustyRatRod
                  RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
                  60,705
                  32365
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  12:33 PM
                  Yeah. Throw those good for nuthin but bein stylish shocks in the garbage. If you want it to ride soft like stock, find some old style hydraulic (non gas charged) shocks for it. You can still find them if you look.
                  I know. Here comes the flames.
                  • Like Like x 1
                  • Agree Agree x 1
                  • ir3333
                    ir3333 Well-Known Member
                    4,583
                    1160
                    Jun 1, 2008
                    ontario,canada
                    Local Time:
                    11:33 AM
                    You are correct Rusty.On smooth roads my improved suspension was indeed nice!
                    ...but most of our roads are dreadful so i took the Bilsteins off.
                    Ride is acceptable now on the rougher roads.
                    • MrJLR
                      5,203
                      5312
                      May 14, 2015
                      Chino, California
                      Local Time:
                      9:33 AM
                      Dang things were expensive but I can keep them on a shelf...
                      I think between tire pressure and the shocks, I might be heading in the right direction.
                      Jeff
                    • RustyRatRod
                      60,705
                      32365
                      Jun 7, 2010
                      Georgia
                      Local Time:
                      12:33 PM
                      Sometimes less is more. It's all dependent with what you want. Bilstein makes a fine product. But they can be harsh in a street environment. I would try the tire pressure first, though. Sometimes that can make a huge difference depending on where you have them set. Also remember too, the pressure on the side of the tire is for MAX load. 9 times out of 10 you're not at the max. I always go by what the vehicle says and adjust from there if I need to. Usually the vehicle specs are far below the max for the tire. For instance, most P metric tires have a max of 35 PSI spec. That's at max load. A lot of times the car on which they are on specs air pressure between 28-32 PSI, so there can be a pretty big difference. You wouldn't think you could feel the difference in 3 PSI, but I promise you can.
                      • Like Like x 1
                      • Agree Agree x 1
                      • MrJLR
                        5,203
                        5312
                        May 14, 2015
                        Chino, California
                        Local Time:
                        9:33 AM
                        I'm going to try this first....it's free and obviously the easiest thing to try!
                        Jeff
                        • Like Like x 1
                        • famous bob
                          famous bob mopar misfit FABO Gold Member
                          16,580
                          6362
                          Aug 14, 2011
                          okla
                          Local Time:
                          11:33 AM
                          Aint funny, steel belted radials do ride rougher that 4 ply nylon tires, think about it , steel belts slapping a sharp pot hole versus a cushiony nylon tire , Just dont hit too big a pot hole too hard w/ the 4 ply !
                          Same thing w/ the stupid rubber band tires on big tall rims , no cushion in the sidewalls , the more sidewall the better the ride..
                          Unless u like to corner carve .
                          • Like Like x 2
                          • MOPAROFFICIAL
                            5,650
                            4632
                            Jun 1, 2016
                            Beach
                            Local Time:
                            9:33 AM
                            Kb, Bilstein both are a firm shock.
                            • Like Like x 1
                            • pro451bee
                              pro451bee Member
                              9
                              4
                              Nov 9, 2011
                              wa
                              Local Time:
                              9:33 AM
                              Old tires will ride rough too , how old are your tires?
                              • MrJLR
                                5,203
                                5312
                                May 14, 2015
                                Chino, California
                                Local Time:
                                9:33 AM
                                3 years old....
                                Jeff
                              • 75slant6
                                75slant6 Well-Known Member
                                5,358
                                1834
                                May 15, 2011
                                Russellville, ky
                                Local Time:
                                11:33 AM
                                I have a dumpster at my house, send me those bilsteins (I’ll cover shipping) and I’ll dispose of them properly. I’m sure the “great” state of California doesn’t want them in their landfills anyway. :D
                                • Like Like x 3
                                • plumkrazee70
                                  plumkrazee70 FABO Gold Member FABO Gold Member
                                  2,509
                                  684
                                  May 5, 2013
                                  Medford, Oregon
                                  Local Time:
                                  11:33 AM
                                  What size torsion bars ya running?
                                  • Like Like x 1
                                  • MrJLR
                                    5,203
                                    5312
                                    May 14, 2015
                                    Chino, California
                                    Local Time:
                                    9:33 AM
                                    Car was originally a /6.....I believe they are original.
                                    Jeff
                                  • plumkrazee70
                                    2,509
                                    684
                                    May 5, 2013
                                    Medford, Oregon
                                    Local Time:
                                    11:33 AM
                                    I'm no expert, but maybe th mismatch with the small bars along with the Bilstein shocks is working against each other. My car isn't near done, but I took advice from @72bluNblu and went with 1.03 bars, Bilsteins and stock HD 6 leaf springs.
