what is going on with this tranny mount situation in my 1976 Duster. I found out Tuesday that the new Anchor tranny mount I put in less than 100 miles ago is bad. The rubber has separated and the insert is moving up and down. must have done that when I launched it last week. I had a problem awhile back trying to get one to fit. I had to wind up buying an insert to press in my old mount because the new mount would not fit. parts house calls for an Anchor part # 2512 for a lot of Mopar cars and trucks. I put an insert Anchor part # 2525 in my old mount and it didn't last. I just ordered a new poly mount from Summit racing and it came in this morning. part # is 4-1603. looks good and sturdy. but it will not fit . it has the same bolt pattern as the Anchor # 2512 mount does. pics below shows the new mount and old mount. the bolt pattern is not going to bolt up. So I just ordered a poly bushing kit for the old mount. part # 5-1101G by Energy Suspensions. BUT I would still like to know what mount fits this car. I have spme other pics here that shows the x member that is in the car. Is this the correct x member for a Duster or is it possible that the tail shaft on this 727 is different than other tail shafts and the bolt pattern is different. if you look at the one pic of the mounts side by side you can see that the one with slots is what the book calls for and the black mount without slots is what is in it that fits the car. has anyone had this problem or can someone shed some light on this problem. I have checked a lot of Chrysler, Dodge, Plymouth vehicles and some trucks and come up with the # 2512 mount as the right fit. Thanks,Bill
