identification 4 speed help
highflyer
oakley ,cal
anybody help me in iding this 833..these are all the numbers i have..tx..j
0B200848?
A-833 4-speed from a (B)Hamtramck car built in 1970 (0) with the a vin ending with 200848.
The numbers under the vin I can not read all in the picture.
PP8333241 0007
PP (new process assy plant) 833 (trans type) 3241? 3241 is Friday, June 12, 1970 (assembly date) 0007 it was the 7th transmission built at the factory on that day. No picture of the tail shaft to know if A, B - E body.
its a" a "body trans,so if its a 1970 trans its not an overdrive trans.am i correct on that..thanks j.?
Correct, non OD unit... at least it better not be. :)
