Jlcaptain24
I'm wiring a 72 Dodge dart w/440 using a Coach Controls Wiring Harness. I have oil pressure gauge and water temp gauge installed. I want idiot lights ALSO. I'm 90% certain these additional holes are for this exact application.
1. That hold on the aft part of the block....it can be used to plumb in the idiot light oil pressure sender, correct?
2. That hole my finger is pointing at can be used for idiot light water temp sender, correct? Technically, I'll have to swap the gauge sender I have in there already to the other whole, to accommodate different thread sizes of the senders.
Just want to confirm. Thx.
