Recently picked up a 75 Duster with a good-running slant. PO had installed an Offenhauser intake, Summit Racing knock-off 600 CFM holley, and a DIY kickdown linkage. When I bought it, carb was full of soot and obviously overfueling. Found that all the stud threads had been pulled out of manifold for carb mounting and it was literally just sitting on the instake- massive vacuum leak causing extreme overfueling, but enough adjustments had been made that car idled and ran just extremely richly. Additionally, carb mounting flange on intake was so warped from PO overtorquing studs, I was unable to machine it flat.
So far, I have replaced the manifold with a new Offenhauser unit and confirmed exhaust manifold is good, no cracks. Installed manifolds with new Remflex gasket and proper hardware, torqued accordingly. Installed a new Holley 0-8007 390 CFM 4 barrel. At this time, I can not get idle below 1500. I have soaked the base of carb, all vacuum fittings, and manifold to head mating surfaces with starting fluid with no avail... I have found ZERO vacuum leaks. Even isolating every vacuum circuit with caps, etc has warranted no change. When first starting the car, it idles where it should and over about 5 seconds idle speed slowly picks up. I know the linkage is all the way closed with new Lokar throttle cable, and even with vacuum advance disconnected car slowly idles up to about 1500 where it is very strong and steady. Is there a chance that the previous owner advanced the timing so much to compensate for the extremely vacuum leak and overfueling that the advance is pulling the idle up? Ignition timing has not been touched by me yet, nor have any of the ignition components been replaced yet, as I'm trying to not introduce too many variables at any one time. Yes, fast idle speed screw is free and idle speed screw is backed out with no more adjustment. Where am I forgetting to check for vacuum leaks, or what do I need to do next? I cannot for the life of me find a leak... all suggestions welcome!
