[FOR SALE] Ignition coil
Garrett Ellison
Up in the holler…
Southwest VA
1971 ChryCo Points ignition coil for sale, p/n 24295531. Labeled for use with external resistor 2444242. Light dent in case from hold down clamp, Ohms out to spec, doesn't leak. $25 Shipped in lower 48. PayPal accepted, Thanks FABO!
I've not seen it leak any. I can leave it inverted overnight to check it if you would like me to. It's been stored on its side and can hear oil in it when shaken.
