[SOLD] Ignition coils, brackets, module, distributor parts
PredaFran
Orlando
2 ignition modules - one works but cant test which - 5 dollars
cap and rotor set - never used - 5 dollars
pickup assembly - never used - 10 dollars
coil brackets (2) - off 2 1973 318s - 3 dollars ea
electronic ignition module wiring harness - 10 dollars
AR engineering AR307 coil bracket for MSD BLASTER coil - 10 dollars
2 canister coils - both working - 5 dollars each
HEI distributor for small block - less than 200 miles of use - 50 dollars
Electronic ignition distributor - works but its rusty - 15 dollars
MSD adapter coil wire (to use a modern coil like the blaster with a stock distributor) - 5 dollars
vacuum canister for Electronic ignition distributor - 5 dollars
ballast resistor - 5 dollars
In Orlando area, 34786
shipping not included
I would like the two coils, the coil wire, the cap and rotor and the AR engineering adapter.
your inbox is full by the way
How much for the pickup assembly, vacuum canister, and the cap clips off of the rusty distributor if you will sell them, all shipped to TN zip 38053. Thanks.
