[SOLD] Ignition switches and key cylinders
halifaxhops
It's going to get stupid around here!
Hoppyworld, PA
Have some ignition switches for sale $60 for the one with the keys and 35 for the rest.
Some 72? up column locks $35 each. And the ride which should be $5 Lower 48. All are NORS older stock.
Even though many of the '68 and earlier aftermarket switches claim they fit all models, I know of differences in some applications. As you can see in the photo, one switch doesn't have the extra nubs sticking out for the later wiring plug that the other switch has. Not a biggie, but, if you're looking to be correct, it might matter. They also made 5 and 6 terminal versions, with the 6th terminal being a ground needed for some dashes. The most important issue can be the way the switch locks into the dash. There's a few different ways they do that so the switch doesn't spin in the dash when you turn the key. Some have a nub sticking out to index into a slot in the dash or cluster, others have a cut-out or flat that does the same thing, and they're not all in the same place. It's best to compare features when getting a new switch if you don't want annoying differences.
