Ignition system questions
tvt59
On my new build I am thinking about using a grid system for the Ignition and using a coil near Spark plug system. What are you guys using in the rear of your block for a camshaft position sensor. Innovators West makes a harmonic balancer with magnets in it can I use this to trigger the crank trigger system.
I’m using a custom machined adapter and a Jeep 4L cam sensor for cam position on Holley EFI. I’m not sure if the power grid has the ability, but with just a crank sensor you should be able to run wasted spark.
There was a guy named superior design products that used to make that collar I wonder if he is still in business
you could lop off 5 of the 6 reluctors in a electronic distributor and have that as the cam position sensor as its a 2:1 rotation. 36-1 would be ignition trigger for a EDIS-6, really easy to do that as the EDIS knows the ignition timing after 1 rotation. Run LS coils if you dont do single coil EDIS.
