H haole Well-Known Member Joined Aug 8, 2007 Messages 639 Reaction score 6 Location USA Aug 19, 2007 #1 Newbie here, I have A 225/6 with a 1920 carb. When I start the car cold , I cant get the idle down when I tap the gas. Do I have to wait 10-15 minutes at high idle for the manifold to heat up so the linkage rod will pull it off?
7 70Valiant Well-Known Member Joined Dec 31, 2005 Messages 179 Reaction score 1 Location Southeast PA Aug 19, 2007 #2 Sounds like your choke pull off diaphragm leaks or your vacuum hose is bad.
